Skidmarx rear hugger
Discussion in 'Maintenance & Tweaks' started by Curtis668, Mar 11, 2010.
  1. Curtis668
    Curtis668
    I'm about to fit a Skidmarx rear hugger.
    On the right hand side of the swingarm, there are two p-clips holding the rear brake-line.
    When the hugger is attached to the swingarm, is there a bracket that holds the hugger to the two vacated holes where the p-clips were originally?
    Or is it considered enough that the p-clips are now attached to the hugger instead?
    If Skidmarx did not intend there to be a bracket with the hugger, I might make up a bracket!
  2. I'm pretty sure mine has a bracket, & pretty sure it's a skidmarx hugger.
    But i'd have to double check.
    Let me know if you need photos.
  3. Penfold
    Penfold
    299
    Got 1 for xmas and looks nice on the bike. If you use the bolts that came with the hugger (5 in total) then they are long enough to go into the hugger and fix into the bracket on your swing arm. Hope this helps.
  4. Whats fit like with these PF? Decent or needs slight modification?
    Antony
  5. Curtis668
    Curtis668
    Penfold, I got nowt with the hugger, just the hugger all on its own!
  6. Penfold
    Penfold
    299
    Mine fits nice mate. Had no problems or issues with it. Wanted something bigger than the original triumph one to help keep the crud off. ;)
  7. Penfold
    Penfold
    299
    Mine was purchased via jack lilley triumph and came with fitting instructions bolts and washers. Will have a look to see if i still have instructions as i may have what the bolts are called.
  8. Penfold
    Penfold
    299
    Sorry Curtis668 gave you some incorrect info :oops: . Just found paperwork i got with my skidmarx rear hugger and i did get a bracket with it. Contents
    2x m5 x 12mm hex head screws
    2x m5 steel washers
    5x m5 x 16mm socket flange screws
    5x m5 nylon washers small
    1x bracket
    Sorry again for that.
  9. Thats what I'm looking for, OEM ones are a bit pump aren't they?! Yours looks the mutts nuts! Though I am a self-confessed CF whore! :oops:
  10. Penfold
    Penfold
    299
  11. Curtis668
    Curtis668
    I've contacted Total Triumph, on the other side of Taunton, who supplied the hugger. They will be contacting Skidmarx shortly. If there wasn't a fitting kit then I would have made a bracket, but knowing that it should have been supplied, I'll happily wait for the kit before fitment!
