Whiter & Brighther Bulb(s) for the 2014 675R
Discussion in 'Accessories' started by SR7492, Nov 6, 2017.
  1. SR7492
    SR7492
    New member - just bought a 2015 675R.
    First thing I want to change is the standard Yellow headlight and Parking bulbs.
    Can you recommend a good quality LED/Xenon replacement that is a simple plug and play? Something in the region of 5000k output which is similiar to a Xenon light (which is 4600k)
    Any links would be appreciated!
    I'm based in the UK!
    Thanks in advanced!
  2. Hahahah literally just posted this the other day. Not a dig just funny the coincidence. I got the Phillips T10 LED's for position lights.
    These
    This shows the difference
    And dipped will be changed to the Phillips crystal white light bulbs, haven't got a link but type that into google and you'll find them.
    They are plug and play and also look good, a little blue'ish but my mate has them on is 899 and they look good/modern against the LED running lights. Also know mine is a 2009 but assume bulbs are the same. Hope this long winded reply helps
  3. You'll need a xenon hid kit, fancy bulbs will never look as white and end up costing as much.
    I bought a cheap kit off eBay for a car and sold the second unit on here, haven't got the link though, and an led lamp for the centre light.
    The kits are plug and play but get one with a small ballast to ensure it fits under the infill ok.
  4. SR7492
    SR7492
    Thanks guys but is the T10 bulb the same for the facelift 675R? The parking light is above and centre of the headlights.
