Wheels for 2013 675r
Discussion in 'Wanted & Swaps' started by Rocky83, Aug 27, 2015.
  1. Rocky83
    Rocky83
    After at set of wheels for a wet set. Please pm or give a shout on 07703035021.
    Dan
  2. cpszx
    562
    you and a bunch of us are also looking for the same. haha.
    can pick a brand new set of wheels up for under 600 but still need the disks, cush etc.
    will be an interesting race to see who manages to bag the first set offered on here. lol
  3. I am running a 2011 model front / disc on my 2013 non R track bike
    not sure if it ll work on the R model but went straight in mine using the 2013 spacers
  4. I have a 2013 rear in my 09 as well, just running 2 abs pulsar rings to space the disc correctly.
  5. gary1966
    gary1966
    3,486
    271
    I missed out on a pair £400 but couldn't get to Birmingham to collect them and I offered to send a courier he wasn't having any of it
  6. Are the 13 wheels a lot lighter then the 12 wheels. And can the newer front be fitted to the early bike.
    • Old Old x 1
  7. W_esty
    W_esty
    638
    148
    The 13/ wheels are weight shaving but this has an issue that they're apparently not as strong / crash resistant as the previous generation 2012 and prior
  8. cpszx
    562
    i dont think theres much to be gained fitting newer wheels to older bikes.
    more the other way, making it cheaper and easier to get wows for newer bikes.
    as there seems to be some confusion, i am just goong to have to give it all a try between my bikes next weekend or so.
  9. No confusion, lots of benefit of fitting lighter wheels, rotating mass is always worth losing.
    All fronts will fit all bikes as long as you use the same age discs ie,
    2006-2012 wheels need 2006-2012 discs.
    2013 on wheels need 2013 discs.
    If you have these combinations they will fit an bike from 06-15.
    06-08 wheels are heaviest, 09-12 lighter, 13 on lighter still.
    Rears are trickier, cush side is no problem any cush will fit any wheel.
    Disc side is more of an issue. All 06-12 are interchangeable and you can fit a 13 rear in 06-12s but you need to space the disc out, I used 2xabs pulsar rings found on the later bikes are ideal spaces as they keep the disc concentric. You may also need to shave the raised casting marks off the caliper carrier but this seems to vary bike to bike.
    The only one I haven't tried is an early rear in an 13 bike, but guess you'd need to machine the wheel to move the disc inboard or change caliper carrier.
    Simple!
    • Informative Informative x 1
  10. 2013 rear with 2x ABS pulsar rings ready to fit my 2009 SE.
  11. cpszx
    562
    how to fit 6-12 rear onto '13 easily is the target.
    will be checking that out after my hols.
  12. I looked into fitting a 6-12 rear in my 13 and as said above the wheel would need machining after some measuring etc me and my engineer friend decide it wasn't worth the hassle / also you would lose a lot of thread depth for the rear disc
  13. I've got a set for sale. Got front, fresh from powder in black and got a rear with disc and abs ring in original dark silver. Front needs new bearings and seals and no discs. Comes with some Metz recetec slicks Here some pics
    1. ai147.photobucket.com_albums_r304_spencerfleet_70d880855b8a8b60b2f39843ad340009_zps3fttwkim.jpg
      ai147.photobucket.com_albums_r304_spencerfleet_6f932527b6a4499660073eddf74ae6a8_zpsyzzipgtq.jpg
      ai147.photobucket.com_albums_r304_spencerfleet_f21006ba4065243f1b1b1d53cb6575ce_zps2snvd5vu.jpg ai147.photobucket.com_albums_r304_spencerfleet_955595e38b961d177f2b00e3f25a3d52_zpsugs1y0zd.jpg
  14. cpszx
    562
  15. zitoune
    zitoune
    Very informative! Thanks
    Do you need 09-12 spacers too in order to fit a 09-12 wheel into a 2013?
    Can you confirm that would fit in a 2013 675R ABS?
    what about the ABS ring?
  16. I have a set of black ones with red pin stripe. They would be without tyres or front discs. Rear will be with disc and cush drive. All in nice condition. Would do 500 plus post
    Sent from my SM-G960F using 675.cc mobile app
  17. zitoune
    zitoune
    I'm in the US. Where are you please?
