Tags:
What year is this engine?
Discussion in 'General' started by processhacker, Aug 2, 2020.
  1. processhacker
    processhacker
    I bought a 675 engine,Ready to refit another bike.The seller said this 2008 daytona engine.
    But i dont think so.
    I guess its 2013 engine.But i dont know its daytona or ST.
    And i bought 2008 ST ECU WIRING HARNESS THROTTLE BODY BODIES AIR BOX.
    So,If engine is 2013,Can i use 2008 ECU and WIRING HARNESS?
    Thanks every one.
  2. Looks like an 09 onwards to me. As far as I know the loom and ecu will work upto 2012. The only issue I think you'll have is the exhaust ports are oval and not round like the 06-08 models so you'll need new downpipes. If you post the engine number someone on here may be able to tell you the year and model of the engine. If not contact Triumph
  3. processhacker
    processhacker
    Yep, U right.
    08 exhaust ports canot use.I think i met unscrupulous seller.
    I'm worried the engine canot wrok with 08 ECU and WIRING HARNESS.
    The engine number is 6503625.look like 2014 daytona.
    Any way ,thank u.
  4. I've got the original low mileage engine from my 2006 Daytona available.
    It was removed years ago when the bike was turned into a full race machine. I have all the ancillary bits to go with it too (and a shed load of other spares too!).
  5. Everything else will work and this engine is actually an upgrade from your old one
    Only thing you need to change is the exhaust headers
  6. And it is a daytona engine as all the black street triple engines had round ports
  7. JohnnyPS4
    JohnnyPS4
    1,310
    315
    Also it’s not a 2014 daytona that’s for sure as it’s got a round heat exchanger
  8. processhacker
    processhacker
    Awesome !
    Street triple ECU can use on daytona engine?
    And how much HP i can get?
    Very thank u.
  9. processhacker
    processhacker
    Maybe 2013 daytona?
  10. Yeah it can be, same power - can download tune ECU and put on a daytona map for free
  11. processhacker
    processhacker
    Any way,thank all guys.
    If engine successful ignition,I will report this thread:)
    Hope works,plz.:cool:
  12. processhacker
    processhacker
    I never used tune ECU.but I will try.
    Thank u,have nice day!
  13. You might need to move some fuses and relays to top of the tank if you use street triple loom as they are different. Airbox just needs a bolt on bracket. Reg/rect is also in different place, on street. Street also has no exup exhaust valve. If yours is on right side front indicator, might be easier to use daytona loom.
  14. I'm pretty sure 2013 onward street triples used the oval port head with different cams.
  15. Think street triples have powder coated sumps, Daytona unpainted. Also Street triples had black starter motor.
  16. midgey46
    240
    Email - [email protected]
    Send them your engine number. Explain you have purchased it and just want to confirm what age and model bike it was built with.
    They’ll help you out, they were super helpful to me when I was getting my track bike.
  17. processhacker
    processhacker
    OK very thanks
