What do I do with this???
Discussion in 'Other' started by Noisygaz, Feb 23, 2013.
  1. Noisygaz
    Noisygaz
    Not the most tech gifted person but can someone tell me what I do with this when fitting a full race system
    1,003
    Re: What do I do with this???
    That's the EXUP valve mate.
    Remove it all, & leave it with your old exhaust system. Then when using "Tune ECU" select "disable Powervalve"
  3. Noisygaz
    Noisygaz
    Top man cheers it's getting a pc5 put on I guess this will do same thing?
  4. chrisw
    chrisw
    81
    If you don't disable the EXBV using TuneECU you will get a MIL on the dash
  5. Noisygaz
    Noisygaz
    Cheers next question is how do I tune ecu??
  6. Re: What do I do with this???
    And is it worth removing with standard system still installed??
  7. Deegee
    Deegee Moderator Staff Member
    7,934
    It's a bit of free software you have to download and buy a connection cable (£10) to let you reprogramme the bikes ecu.
    No. Unless you're having serious problems with the exup valve, or you plan on going full time track bike.
  8. Noisygaz
    Noisygaz
    cheers fella
