Two fuel pump connectors?
Discussion in 'Maintenance & Tweaks' started by sean, May 16, 2019.
  1. sean
    sean
    Hi after some digging I noticed I had two brown fuel tank connectors under my tank, a little research later and I believe I have had a fuel pump relay wire harness fitted, as the bike originally did not have a relay, I was wondering if anyone knows what the white connector is supposed to be connected too?
  2. StephenP
    380
    Odd but I know on mine the white ones are for the CPS and stator.
  3. StMarks
    Looks to me as though the Bypass relay harness is there, but you've not connected it.?
    Iirc the brown plug on the main harness should connect to the white plug on the sub-harness(instead of directly to the pump) & then the Brown plug on the sub-harness connects to the pump.
    This is to avoid overloading your ECU.
  4. sean
    sean
    So this is the "extra loom" or the retro fitted by triumph fuel pump relay loom, it's the white connector pointed by the blue arrow that I'm struggling to find a location for
  5. sean
    sean
    Oh i see I'll try later if that works, cheers
  6. bladebiker
    bladebiker
    987
    45
    Is this the mod that was done under a recall ?
  7. sean
    sean
    No idea m8, only found out about a possible retro kit by reading a Haynes manual
  8. StMarks
    Yes, that's the one Bb.
  9. bladebiker
    bladebiker
    987
    45
    Thought so .
  10. StMarks
  11. sean
    sean
  12. Tyler Kemp
    Tyler Kemp
    7
    so where did the smaller white connector go? Mine wasn’t plugged in before and just got a new sub harness. I found where the black one goes though
  13. Tyler Kemp
    Tyler Kemp
    7
  14. StMarks
  15. Tyler Kemp
    Tyler Kemp
    7
  16. Tyler Kemp
    Tyler Kemp
    7
