Right, I’ve had a guy full of trying to reset my damn TPS... I had one fail last year so I fitted a new one on a clean set of throttle bodies, along the way also fitted my old manual idle along with removing the ISCM/ stepper motor. Bike fires up after a while ( cps maybe failing) Trying to reset my TPS as the new one has started tithe the 4-5k lull on throttle. The bike can be idling for 20mins with no result. Does the bike need to be stone cold or can it be 25c before start up? Also does the reset method only work with the idle motor plugged in?
