Suspension set up
Discussion in 'How To's' started by cpatel89, Jun 10, 2021.
  1. cpatel89
    cpatel89
    12
    Hi All
    My apologies if there is already a topic about this.
    I recently had a fork seal leak and got my forks serviced by k tech (new seals, dust covers and oil)
    They set the suspension up back to factory settings but I find it way to stiff for my liking. He did mention that the set up was a couple off clicks out
    My riding experience is with this bike only 2010 Daytona.
    Should I leave it as it is or shall I adjust the suspension the few clicks.
    If I should adjust it can anybody advise what he means by clicks I’ve never changed the settings on the suspension before.
    Thanks
    852
  3. cpatel89
    cpatel89
    12
    Appreciate that, seems a bit too much to read at this time off night I’ll give it a good go tomorrow
    Thanks
  4. R4CKS675
    R4CKS675
    98
    12
    There's standard settings in your manual. Got different settings for sportier or softer rides. I have mine set halfway between sport and soft as the sportier/harder end is too stiff for my weight and the bike just skips over bumps.
    Sent from my VOG-L09 using 675.cc mobile app
  5. cpatel89
    cpatel89
    12
    I seen that last night and I was thinking exactly off what you said and see what happens, the one thing I need clarification on is in the book it said the clicks are from the closed position. Would that be from when it’s set to the hardest?
  6. It should say on the table but damper settings are usually clicks back from fully clockwise position, preload is sometimes the opposite, although that depends which page I read in my Thruxton manual:mad:
  7. cpatel89
    cpatel89
    12
    I read my manual and lucky it’s from the fully closed positioned so I’ve assumed that it’s like anything (righty tighty) and set it in between the standard and the sports setup like @R4CKS675 has done and it seems alot better back to what I was use to, but I’ve booked it in at rjs at Mallory to set it up properly
    Thanks for all the helps guys
