Stuck in 2nd gear.
Discussion in 'Maintenance & Tweaks' started by CamPhair, Feb 26, 2019.
  1. CamPhair
    CamPhair
    As the title says.
    All linkage etc doing as it should but can't get it to change gear in any direction.
    Fitted a new slipper clutch recently. Put the bike in gear to remove the clutch nut and it worked fine then. The clutch is working fine.
    I've tried starting the bike and letting it run but this didn't make any difference.
    Open to any suggestions.
    Ps it's a track bike with race shift and after market rearsets.
  2. In the mix
    In the mix
    217
    10
    Butterfly spring has popped off the selector shaft by the sound of it mate
  3. CamPhair
    CamPhair
    Does that involve a strip down?
  4. CamPhair
    CamPhair
    Problem solved.
    When clutch was removed the spring was in the position in the first pic.
    The second pic is how it should be.
  5. CamPhair
    CamPhair
