Steering 1 inch off centre after a off.
Discussion in 'Chassis' started by tonyk, Oct 2, 2015.
  1. tonyk
    tonyk
    Guys, so called fixed wing mirror, indercator, and a few scratches, and went for a spin only to find the handle bars a about 1 inch pointing to the left.... If I let go of the bars the bike still goes straight, if that helps.
    Any comments or a dealer job ?. If so how much, Ball park figures please.
  2. are the forks twisted in the yokes? try undoing bottom yoke bolts and loosen front wheel & put between legs and try and straighten.
  3. rather than put it between your knees, loosen off the lower clamps and give it a bounce. It should straighten itself out. Watch the bolw for better instructions.....works a treat
  4. Stu675
    Is it just the clip ons? are the locating lugs broken off?
  5. tonyk
    tonyk
    Can't see anything broken, not clip on's.
  6. Electric kid
    Electric kid
    705
    105
    Like Stevo said. 99% sure it will be the forks twisted in the yokes. Mine did the exact same thing.
  7. Yep I had the same after slow speed off on track if they are twisted in the yokes it'll prob make a bang once u loosen both top and bottom yoke bolts then simply tighten up and go have fun
  8. Buzz I thought you twisted frame and forks... when you got knocked off... but it simply pinged back once it was loosened
