standard loom to race loom
Discussion in 'Chassis' started by g6xer, Feb 26, 2020.
  1. g6xer
    g6xer
    hi,
    i am wondering if any of you real technical guys have a schematic for a race loom i can make from a standard loom?
    this will include the removal of the ignition,lights & sensors ect?
    many thanks
    Paul
  2. When I did mine I just printed out the wiring diagram (plenty of decent copies on Google) and used that to remove all the unnecessary wires.
    I also used the street triple relay bracket that bolts to the airbox and relocated everything from the LHS fairing, much easier for a trackbike and protects them in a low side.
    • Creative Creative x 1
  3. g6xer
    g6xer
    i have been told to do that i.e. moving the fuse box. i low sided in Spain a few weeks back a tore through some wires in turn burnt out my speed sensor
    wouldn't run right after that,
    the loom i have is a bit beaten up now so thought i would start from scratch to help protect it in a crash
  4. Scottyjm675
    Scottyjm675
    Please do a photo guide, I need to do also but have no clue where to start
  5. JohnnyPS4
    JohnnyPS4
    1,310
    315
    What year is the bike? I’m about to swap mine on my 12 for a street triple loom +reg/rec and airbox, not fitted it yet but I’ve been reliably informed it plugs straight in, only change needed is a bracket to relocate the air sensor from the air intake to under the seat. Means it’s all tidied up with relays etc sat on the airbox and reg/rec mounted as per kit loom
  6. Scottyjm675
    Scottyjm675
    2011 mate, I should be able to do the same then?
  7. JohnnyPS4
    JohnnyPS4
    1,310
    315
