Sprockets
Discussion in 'General' started by Stu, Mar 27, 2021.
  1. Stu
    Stu
    My new to me 2010 came with a 47t rear, am I right in thinking it should be 45t? If it's been changed will the speedo be out and if so, will it read over our under?
    I've ordered a phone mount so I'll be checking it against three GPS on my phone when it comes!
  2. Ntecuk
    Ntecuk
    1,539
    31
    If it's non abs Might be fitted with a SpeedoDRD or similar to correct the issue.
    If you have abs you might not need to do anything.
    Sent from my Redmi Note 9 Pro using Tapatalk
  3. R4CKS675
    R4CKS675
    87
    9
    No abs on 2010 bikes, only on certain gen 3's.
    In terms of the sprocket itself, from what I understand this just effects gearing ie acceleration OR top end. It should have no effect on the speedo readout afaik
    Sent from my VOG-L09 using 675.cc mobile app
  4. Ntecuk
    Ntecuk
    1,539
    31
    Older bikes used a pickup on the output shaft for the speed pulse.
    Pretty common on lot's of machines.
    I think tune ECU has the ability to correct the issue too
  5. CamPhair
    CamPhair
    150
