Tags:
Slow leak
Discussion in 'Maintenance & Tweaks' started by Frankssy, Apr 15, 2021.
  1. Frankssy
    Frankssy
    Any help with this would be greatly appreciated!
    I have a slow acting (probable) coolant leak that causes 1-2 droplets on the garage floor each day and the drops are falling from multiple points beneath the bike. I've attached a few photos to show where the drops are forming. I've checked the hoses and they are bone dry and cannot see any obvious streaking/residue to show the path of the leak. There does appear to be some dampness around the seal where the hose re-enters above the side stand, but that is far away from the drops shown near the oil filter. Also can't see a wet trail to follow to the source from the droplets .
    Any ideas anyone?
  2. cpatel89
    cpatel89
    286
  3. cpatel89
    cpatel89
    286
    If you bolt that connector off you will find a seal which should be perished, I had the same issue and it was leaking from there going onto a breather hose that was to the left off it and onto the sump
  4. As @cpatel89 says there's a gasket behind the centre T piece and an O ring were the pipe connects above the side stand, either could be leaking, or both.
  5. Frankssy
    Frankssy
    Thanks both, really helpful. Both seem to be leaking so I've ordered a replacement o-ring and gasket.
  6. cpatel89
    cpatel89
    286
    What years are your bikes mines a 2010 but it doesn’t have a gasket only a o ring
  7. I was going off the parts list on Fowlers for a 2013 bike which shows a gasket behind the centre T piece, but I haven't had mine off to say for sure.
    Assuming from the pic OP's is a 2013+.
  8. cpatel89
    cpatel89
    286
    Ahhhh fair enough
  9. Frankssy
    Frankssy
    Quick update for those interested. 2015 bike. I had two leaks and ordered (parts 24 & 25 in the above diagram). The gasket I removed was definitely disintegrating from the outside inwards and in need of being replaced. After replacing that I then unbolted part 16 and removed the o-ring inside. That one looked alright but a bit flat around the edges and not as fresh as the new one. The water inlet needed some force to get it back in as the new o ring was tight but it wasn't too bad, cleaning the old gasket off was less fun. Leaks fixed thanks @cpatel89 @wobblybiker99
    • Informative Informative x 1
  10. Out of curiosity has it always had Triumph coolant replaced at the 3yr intervals?
    I wonder if the T piece was removed when somebody fitted the Samco hoses and they didn't replace the gasket.
    Glad its sorted, I think mines due a coolant change this year.
  11. Frankssy
    Frankssy
    I've replaced the coolant myself about once a year on average. I did get my garage to fit the hoses for me as I didn't have the time when they needed doing. I trust the garage I use but you never know. Other theory I had was all that salt and other gunk from the road got in and damaged it over time. Either way glad it's fixed and learned something new along the way.
  12. I know this thread is been done, but man I'm having the same issue!! I tore the bike apart to clean it cuz I haven't done that in 5 years hahahaha, changed oil and filter, this morning I saw the cooland puddle and it looks just like yours.
    funny thing is that before me cleaning it there was no leak, I even took a 1000 kms ride the last weekend and it was just fine
    anyways, this info helps me a lot to find the leak.
    cheers from mexico!!!!
  13. I had a Leak that looked exactly like this. My source was centerline, front of the motor, 1in hose going vertically with metal hose clamps. Just had to tighten those up a bit for me.
