Servo removal on daytona 13? Any advice?
Discussion in 'Accessories' started by 675oxford, Dec 23, 2013.
  1. 675oxford
    675oxford
    Trying to find servo location to remove
  2. The motor is located just in front of the rear shock, remove the 2 bolts and it should slide out with some engouragement. Zip tie the connector to keep it out of the way , you could tape it with electrical tape aswell .
    Pics from revolution racing:
  3. 675oxford
    675oxford
    Thanks for your help all sorted! Loving the race fit!!
  4. Np, please post pics and video/sound clips if possible.
  5. gary1966
    gary1966
    3,486
    271
  6. If he didn't have it remapped it will be, no way around it yet. Si at TRS says that tuneboy are working on cracking the 13 ECU atm, if they are successful that's a far easier/cheaper way than having to get the bazzaz/pc5 + full system map and dynotime.
    Being able to turn the EXUP off means that you can use Triumphs arrow slipon map for any aftermarket slipon, that will be a lot better match than the full system maps you need now to get rid om the eml.
  7. gary1966
    gary1966
    3,486
    271
    I have the arrows map at the mo, the only reason I haven't changed it is because of noise levels as I no the arrows will pass a noise test on track and that's only because the exup is connected just not sure on noise levels when using a can without the exup connected
  8. 675oxford
    675oxford
    Eml is on but can't be helped. Going to get the arrow map on it
  9. 675oxford
    675oxford
    At the moment it's 103db so not too bad
  10. gary1966
    gary1966
    3,486
    271
    Depends how you look at it? my arrows is 96db in neutral so fine at trackdays and when old bill pull you over.
  11. gary, what db readings do you get without the baffle on the arrow
  12. gary1966
    gary1966
    3,486
    271
    Not sure but theres hardly anything in it in my ears.
