Running light on front fairing 2014 Triumph 675R
Discussion in 'How To's' started by rob kirk, Apr 2, 2020.
  1. rob kirk
    rob kirk
    Like to know how hard and how to remove the bulb that goes between the 2 headlights
  2. RICH675
    RICH675
    564
    Hi @rob kirk
    I changed my screen and did it then. Not a massive job and there may be an easier way tho.
  3. I think it’s sandwiched in by the screen, i could be wrong though
  4. rob kirk
    rob kirk
    RICH 675 . Does the front nose fairing have to come off ? What is the best way to get to the bulb ?
  5. rob kirk
    rob kirk
    Whats the best way to get to this bulb?
  6. D675hogg
    D675hogg
    144
    14
    Just need to remove the screen that’s all. Simple job.
  7. rob kirk
    rob kirk
    Could you give me more information on removing the screen, need help thanks
  8. D675hogg
    D675hogg
    144
    14
    It’s a few bolts that need to be undone at the top the screen that connect to rubber bolts on the underside. 4 of them in total if I remember. The screen will then pull out towards the tank. 5 min job if that. Don’t think you have to take the mirrors off but if you do it’s another 5 min job.
  9. rob kirk
    rob kirk
    Thanks, I will try today, just a little confused on what you call the screen ?
  10. D675hogg
    D675hogg
    144
    14
    The windscreen...... yellow circle.
    4 bolts.... red circles
  11. towser
    towser
    841
    37
    Mirrors at least need to be loosened.
  12. rob kirk
    rob kirk
    Thanks guys, it worked so well and again thanks to all
  13. D675hogg
    D675hogg
    144
    14
    Good stuff. Glad you got it sorted.
