I want to remove the passenger footrests but as you know it leaves the uncoated mounting points. What are the options to cover them? I know you can get blanking plates but can you get any black bolts or anything along those lines that does the job nicely???
You can get little black bolt-hole covers from Halfords....they're 'car door panel trim covers' or sommit like that?? Anyway, they're really cheap and you get loads of them.
In all fairness the chrome headed ones look fine as all the engine and fairing ones are also chrome headed, think they set the black frame off nicely all matching
Ill have a look for those in halfords thanks for that. Also like the idea of painting the bolt heads black. The carbon4u blanking plates look quite trick but stand out a bit. I want to try and blend it in with the frame more.
