Question regarding Aim Solo 2 DL Fork Mount
Discussion in 'Accessories' started by DanDaytona, Jul 19, 2023.
  1. DanDaytona
    DanDaytona
    Hi,
    I have a 2009 Daytona with standard forks. I'm going to buy a fork mount for my Aim Solo 2 DL, and I have to choose a diameter. What is the diameter of the forks please? I believe it's 41mm based on some Google research - is this correct?
    Many thanks
  2. Carlos675
    Carlos675
    41
    Hello!! 41mm is the diameter of the inner bar, in any case you will need to know the diameter of the bottle (In Spain at least we call it that) The bottle is the outer, golden bar. Which is te diameter that you will need for the AIM support, I hope the translator is not playing a trick on me... and I understand you well!
