Now I'm no expert.....
Discussion in 'General' started by SW73, Oct 18, 2023.
  1. SW73
    416
    So...test ride threw up an exhaust blow from the usual place... balance pipes on the headers. Fortunately I've a pal who knows a man, who knows a man and they've kindly made one new balance pipe which was holed and welded all sorts of cracked bits and pieces, adding a bracing bar like the gen 2s have...I think . Anyway...all good. Currently in the Dordogne so bits to do when I get back. Nearly there now though! IMG-20240611-WA0010.jpg IMG-20240611-WA0011.jpg
  2. cpszx
    554
    the brace stops the main pipes moving when the link pipes are being welded,
    i have a set that a local guy did without the brace, and will need some realignment before they could ever be used :pan:
    lucky i had a spare set at the time.
  3. SW73
    416
    I'm going slowly...but nearly there now! Exhaust fitted back up perfectly. A minor mod to the lower radiator stays (which had rotted off when I got the bike necessitating a new one. I've now got 2 coloured side cowls (Thanks @cpszx ) and some side protectors en route (thanks @StMarks ). Cleaned the bobbins with brake cleaner and it looked like they hadn't been floating at all so set about them.with a nut and bolt. Seem a lot freer now but if not I'll be looking for new R discs. New grips/indicator housings and a good clean and it's done. Really enjoyed it. Once sorted I'll look to service the front forks. PXL_20240628_195607348.MP.jpg PXL_20240708_150156178.MP.jpg PXL_20240703_142401202.MP.jpg
