Can you get a video up do you have a baffle?? that link pipe is going to look the tits once it starts going blue think I am going to remove my arrows and get this exhaust, a sound clip would swing it.
Well happy with it. No it's not the triumph website it's mine I bought it from race fit il put video up as well but it doesn't do it justice. Il be at h cafe over the summer to show it off. Was expensive but as uv all said it looks the nuts!!! iv tested it at 103db so with the baffle I have it should be fine on track. I just need it remapped
You sure the cat is gone ? Looks like it's still there in the pic, the bulge just before the start of the slipon pipe. To get rid of the cat you have to either cut it off and weld a new piece of pipe in it's place it or install a full system. It's welded to the collector and the downpipes so you cannot just remove it without quite a bit of modifications.
I thought it was part of the stock exhaust. I'm not 100% sure so maybe not. But it did weigh a lot so I presumed it was all one piece??
Did it take you long to do mate. The reason I said triumph was I sure they were selling a race fit one lol
The stock exhuast is very heavy, the large square box that you removed is part of the muffler. The cat is the thicker piece between where your slipon starts and the collector. The thicker part here is the cat , pics from revolution Racing: Here it's cut off and a pipe is welded in its place :
