I bought a second daytona to brake it for parts. 2008 model, 29000 kms stock apart from arrow slip on, gilles rear sets, de-cat, de-EXUP and an arrow slip on map (20420). It was in a great condition apart from the right side that was slightly damaged so I decided to turn it into a budget track bike. I replaced the loom with a 2009+ one that I had laying around from my race bike as I wanted to install a quick shifter. And here is my question. The bike starts fine, no error codes, all is well. The problem is that I try to upload via TuneEcu a map from the 2009+ model (in order to use the quick shifter) but TuneEcu dont allow me. "The map is not compatible with this ECU" I thought that it could be done. Is there a way to upload a different map?
Yes The bike is running without ANY issue. No error codes, everything is ok. The only thing is that i want to download on the ecu a newer map (for the 2009-2012 model) so that i can run a quick shifter. Tomorow I ll try to conect the shifter from my race bike to check if it is working.
Quickshifter works by cutting the coils through the ECU, you need the 09-12 ecu (and sadly clocks aren’t interchangeable either)
Thanks for the replies Just for the record I connected my qs and it didn’t work. I contacted 2 local tuners with experience in triumphs. The first one had no idea, but the second said that the later ecu has different processor and as a result it can’t be done. You can’t download a 09-12 tune to a 06-08 ecu. So I am after a reasonably priced 09-12 ecu and clocks set. Or even better a kit ecu and loom.
Ultra fast keto boost Ultra Fast Keto Boost is a weight loss supplement that comes in capsule and bottle form for 30 days. Each Fast Fast Keto Boost pill provides 800 mg of BHB ketone, including calcium BHB, sodium BHB, and magnesium BHB. Read Here > https://testoboostersupplements.com/ultra-fast-keto-boost/
