Tags:
Indicators...
Discussion in 'Accessories' started by Little_cusdin, Jun 3, 2020.
  1. Little_cusdin
    Little_cusdin
    Evening all!
    I've got standard indicators on my Daytona and just look so bulky. Ideally I'd get the genuine triumph LED ones but can't justify spending £200 on them when my current ones work perfectly fine, my question is are there any aftermarket LED ones you'd recommend that are worth swapping too?
    Cheers,
    Dan
    1,003
    Front or rear, or both.?
  3. Hogster
    Hogster
    418
    32
    Watsen indicators for the front, no longer made but someone may have them.
    Are you ok with wiring, if so I could recommend rears too by motodynamics.
  4. Little_cusdin
    Little_cusdin
    Both
  5. Little_cusdin
    Little_cusdin
    what's wiring? :lol: I could get my mate to give me hand but ideally something fairly straight forward.
  6. StephenP
    399
    Lghtech also do some nice looking indicators, for them on my rear.
    I'd you can track down some watsebs but then quick.
  7. Hogster
    Hogster
    418
    32
  8. Little_cusdin
    Little_cusdin
  9. R4CKS675
    R4CKS675
    155
    24
    Yep that's me. I paid £35 a pair which is a hell of a lot cheaper than genuinentriumph ones but it does come with some complications, particularly on the 2013 bikes.
    I had to cut the wiring about to put new mini bullet connectors on the bike to take the indicators. For some bizarre reason, if I fitted the resistors that come with them front and back the front ones didn't work, took the front resistors off and work fine.
    Secondly, as the wire runs through the centre of the bolt and you just have the 1 bolt I had to make up some aluminium blanking plates to cover the fixing hole of the original indicator. This came with the added consequence of the original indicator also forming the mount for the reg/rec in the left hand fairing. So had to make a plate up for this as well that I fixed to the reh/rec and it extended far enough to pick up the bolt on the rear of the new indicator.
    All in all, worth it in my opinion. Nice slim profile, black so blends in with my bike and I like the dynamic scroll as they indicate too. IMG_20200529_130443.jpeg
    • Informative Informative x 1
  10. SW73
    427
    Just my thoughts but the Watson's on the front and triumph genuine LEDs on the back would be a good set up. If you put a wanted advert up I'd be hopeful of sorting those second hand for a significant amount less than brand new. And they're quality items in my experience. Worth an ask?
