Can anyone help, I've been fitting my new Rizoma fat bars and risers tonight but am having clearence issues with the headlight cowl..... The front brake line where it comes out the master is catching the cowl on left lock. Has anyone else had this problem??????
you could loosen the banjo bolt and turn the brake line in or out (in looks better) to get it out of the way of the cowl.
^ As above. Shouldn't need to re-bleed it either, if you undo it just enough to move it. Be quick though, fluid will start leaking out. Make sure you cover and parts underneath it will a towel or something. How are the bars? Any problem with width?
All done, thanks for that guy's...... Just been out for a short ride and the bars feel good to me, i've just fitted the Rizoma rearsets as well so the whole bike feels totally different at the mo, in a good way though, just need to do some small adjustments to the rearsets amd levers to get perfect. REALLY happy though!
