The tethers not actually attached there, I was in the process of taking it off to test the front when I took the picture for a friend I was chatting to via whatsapp at the time. The tether loops round and through the hanger so if the camera came away it wouldn't get any lower than it is when mounted it would just be loose. Sorry it the pic was misleading. If you zoom in if gallery it you can see its not connected.
Don't worry CS those Irish lads alway miss stuff [FACE WITH STUCK-OUT TONGUE AND TIGHTLY-CLOSED EYES] I thought the same before you explained tbh, I have lock wire attached to the subframe that goes to a split pin that goes through the axle bolt. It was like it when I bought it, going to cut it off later though as I have horrible visions of something similar happening.
I've got mine on the tail in between the two mounting bolt holes on race fairing. On the tank near the front so I can still get tucked in
Just recieved mine and it didn't come with screws. Also, it's tiny?? How did you fit that to where the mirrors mount?
Ah bugger! You use it on track fairings, drilled your own holes? I bought it thinking it would mount on the existing mirror holes
I used the main half of a bicycle mount. Removed one of the well nuts from the screen, got a slightly longer bolt and bolted one side on using rubber washers, don't want to mark the paint. The other end of the mount I just taped a rubber stopper on it to stop any vibrations.
I mount mine with a anti roll bar clamp onto the headstock nut in the centre of the forks so it's looking straight through the screen
