Facebook, Instagram & 675.cc Featured
Discussion in 'General' started by Craig, Apr 28, 2015.
  1. Craig
    Craig
    Administrator Staff Member
    4,893
    227
    Thanks for the pictures everyone, It's great adding them on facebook some great shots! :D
  2. 675RX
    675RX
    101
    27
  3. 675RX
    675RX
    101
    27
    And again in the pits
  4. My 2009 SE at Donnington.
    My 2006
    Carbon tail
    Ducati 999s front wheel and disc's
    2010 monoblocks
    Brembo Rcs master cylinder
    2014 slipper clutch
    Decat custom exhaust system
    Pro Mach rear sets
    HM PLUS quick shifter
    named 1/4 of mods :) this help???
  6. -LG-
    -LG-
    94
    My 08 D675
    Suspension:
    - OEM Forks re-valved with Racetech Gold valves and Wilbers 10.5 Fork Springs.
    - OEM Rear Shock also re-valved with Racetech Gold valves and fitted with an Ohlins 13.5kg spring
    Deleted OEM Gear:
    - Removed Intake Flapper
    - Removed SAI (Rerouted crank case breather to Reed Valves)
    - Removed O2 Sensor
    - Removed EXUP Valve
    - Removed Idle Stepper Motor
    - Removed OEM Rad Overflow Bottle
    - Removed ignition (replaced with missile switch)
    - Removed Heat Exchanger
    - Removed left switch block
    Intake and ECU:
    - BMC Filter
    - 09 D675 Velocity Stacks
    - Balanced TB's with TuneECU
    - Uploaded Custom Map
    - Installed Manual Idle Control
    <b>Engine:
    Stock
    Exhaust:
    Custom built low mount system using OEM Headers. System uses a cone engineering merge collector to 2" pipe leading to a SP Engineering muffler.
    Brakes:
    - Yamaha R6 front calipers
    - R6 Braided lines
    - Brembo RCS19 Radial Master Cylinder
    - OEM Rotors
    - SBS Sintered Pads
    - OEM Rear brake
    Other Mods:
    - Renthal Sprockets
    - DID 520 ERV3 Chain
    - Lightech Chain Adjusters
    - Axle Armour sliders on the rear and home made sliders up front
    - GB Racing case protectors and frame sliders
    - Alien Motion Li Battery
    - Motion Pro Rad overflow bottle
    - Attack Rearsets
    - HM Plus Quickshifter
    - Cox Radiator Guard
    - Renthal grips
    - Samco Sport hoses
    - JHS Oil Cooler
    - Monkey Bones front brake guard
    - HM GPS Dash
    - Hyperpro top mount steering damper
    - Motoholders Fairing Stay
    - SES Lock Stop Protector
    - NJCustoms Tank Sliders
    My new toy Speed Triple S
  8. Funky night time shot
  9. Are any of these worthy?
    auploads.tapatalk_cdn.com_20161014_b72c2727876d948b760d3a64c9e9036c.jpg auploads.tapatalk_cdn.com_20161014_0e7bfd5184b3876cbaf81d7398c6199b.jpg auploads.tapatalk_cdn.com_20161014_de3da90456a2cbad7448ba77759e2189.jpg
  10. Craig
    Craig
    4,893
    227
    That looks like the Grasshopper Westerham! :D
  11. You're spot on mate.
  12. sean
    sean
    250
    My baby. I love this bike
  13. Hmmmmm looks very nice and clean Sean, needs some rim tape though to brake up the darkness lower down ;)
    White or Amber
  14. Craig
    Craig
    4,893
    227
    Fantastic pictures guys and gals! I've got to the end of the list so if anyone has anything they would like to echo across onto Facebook and soon the front page of this site please post the pics here!
  15. [​IMG]
    Not sure if they are any good, my old R model with Arrow pipe, LED indicators etc
  16. volant
    volant
    866
    276
    Any good? I really should get round to taking some proper ones on my DSLR...
    Touring in the Pyrenees, who needs a GS?
    Touring in Wales, again, who needs a GS?
    Brands Hatch
  17. volant
    volant
    866
    276
    Slightly off topic, in as much as I'm not sure if this is what you're after as its not actually my bike as such, but this is my Daytona wedding cake topper from last month...
  18. Craig
    Craig
    4,893
    227
    haha love the cake topper! I might pass that idea to my partner - 20 months to convince her it's a great idea! :D
    Thanks for all the pictures so far, I've started to add the facebook posts to the main page of this site. It's great having a regular flow of images, helps with the site :D Thanks once again all :)
  19. Cluck
    Cluck
    27
  20. Cluck
    Cluck
    27
