Hello. I’m trying to adapt 2013+ headers to my 2010 as OEM or aftermarket parts seem to be unavailable for my year. Everything is lined up so far but the cat section of the new header assembly is touching the oil pan. Is this by design for the 2013+ models...did the pan get modified to accommodate the new exhaust? Thanks in advance.
Don't know what the 2010 bikes are like but the oil pan on the 2013 curves around the cat. Sent from my ONEPLUS A6013 using 675.cc mobile app
Thanks. My 2010 probably has the same curve. I solved it with a 3-lb sledge since I gutted the cat and could afford to have that “expansion chamber” be a little smaller. My welds won’t win any awards, but I was able to connect the front section of a 2017 header to the back part of my 2010 with one joint and moving the rear mount a little.
