As the title suggests I'd like to know of 2010 forks have pinch bolts on both fork lowers? Here's mine
Do you think that if I tighten the axle to the 65nm and then loosen the pinch bolts I could even the axle out?
They look like they have been repaired. Was the thread been stripped and an insert put in, which is held in my the 2nd set of pinch bolts??
They have come off a bsb supersport that didn't race this year as sponsors pulled out. If they have been repaired there really is no sign of it other than the fact that there is an insert in the receiving side.
Could the one on the right be an earlier fork bottom that has been adapted? I think they had the pinch bolts on that side, where as the later ones swapped to the left.
