Daytona gen 2 engine in gen 1 bike
Discussion in 'Other' started by Nik, Jun 12, 2022.
  1. Nik
    Nik
    108
    Just finished putting the bike back together and was hoping to start it but not having it.It doesn’t even seem to get the fuel pump in action ready to go let alone turn over.All I’ve swapped is the engine and also put a gen 2 ecu in,which like everything else just plugged straight in.
    Wondering if anyone out there has some experience and advice that might help me.
    Cheers Nik
    986
    Side stand safety circuit perhaps.?
  3. Nik
    Nik
    108
    I did think this myself but if the circuit is closed or open if the bikes in neutral it should still start right.Thanks for your thoughts none the less
  4. No experience with engine swaps but what about the tip over sensor, assume that would stop the fuel pump/start?
    Other than that Tuneecu would be a really useful tool, can see all the safety interlocks and sensor states, and activate fuel pump and other things manually to check relays & wiring.
  5. panos_zip
    panos_zip
    50
    did you swap the cluster as well?
    The ecu and the cluster must be of the same year.
    09-12 or 06-08
    If you used the gen2 ecu, with the gen1 cluster it will not start.
  6. Do they have to be "paired" as well, or just the same gen?
  7. Nik
    Nik
    108
    A couple of things to have a look at their then.
    I completely overlooked the importance of compatibility between the clocks and ecu.I have a gen 1 ecu in the garage I can try and I shall also check the tip over switch connection and positioning.Will let you know.
    Cheers for the help folks.
  8. Nik
    Nik
    108
    Only paired(coded) on the gen 3 bike.
  9. panos_zip
    panos_zip
    50
    For gen1 and gen2 bikes, they only have to be from the same gen
    For gen 3, as Nik said
  10. Good to know, wasn't sure because I have a gen 3 and know it applies to mine.
    Hope the dash swap fixes the OP's problem
  11. Nik
    Nik
    108
    Finally made the time to put gen 2 clocks on that match up with the gen 2 ecu.Progress made as it sounds like the fuel pump is coming into action and the bike now turns over.But still won’t start.I was wondering if anyone knows anything about the important of compatibility of injectors.After try to start it on numerous occasions no smell of petrol,which I was expecting.Or maybe I shouldn’t expect this.Would appreciate your knowledge fellow 675 enthusiasts.
    Cheers Nik
  12. StMarks
    986
    Are you sure about the fuel pump priming Nik.?
    If it is, then the below information will not apply.
    Nonetheless..
    Because you have a Gen 1, and you changed the ECU at one stage...- Is it possible that you may have wrongly allocated the (recall subloom on early Gen 1) fuel pump supply cables so that it is no longer served by a relay.?
    Some pertinent reading here Nik.: https://675.cc/threads/two-fuel-pump-connectors.38290/
    Hth.
  13. Nik
    Nik
    108
    Deep joy,got the bike running today.Thanks for the good advice folks but the solution came to me when I woke up the other day.Tried the gen 1 ecu and also made sure of a definite click when connecting the fuel hose to the pump( I know a very basic error).
    Either way I now have bike I can proceed to finish putting back together when some small parts come in.The poor machine has been an emergency donor for a few bits for my race bike over the last 2 years.
    Regards Nik
