I have ISR brake master cylinder and I would like to use matching ISR clutch lever with it, but the clutch switch is the problem on stock clutch. Is there any way to remove it / bypass it or do I have to use the stock clutch?
If you have an 06-08 you can just bridge the wires If you have 09-13 and the triumph quickshifter you have to fit a push button switch to temporarily cross the wires which acts like pulling in the clutch When I did the above I wired it up using the horn button on the left handlebar switch gear to keep it looking stock Or you can fit one of these (7/8” width) If you’re not using a quickshifter then crossing the wires is fine
Great. Thanks for good reply. Just to make sure, I can just bridge the wires? I have -08 with aftermarket qs.
Yeah you’re good to go bud Do it half way down the loom so it’s easily reversible Join them up and test, then make more permanent Just be warned it will start in gear now haha
