Hi all Who's had this problem . At Mallory on Sunday on the sighting laps clocks went blank, rev counter was still working . Came into the pits turned bike off and rev counter stuck at 6000. Turned ignition on ,rev counter still stuck at 6000 ,oil light on and fuel pump DID NOT PRIME . Engine turned over well showing strong battery. Is this a problem with the clocks ,Reg/rec or ECU. Checked plug connectors . Read lots of threads on R/R failing sending the clocks ape but not where the fuel pump didn't prime. Any replays would be much appreciated . Not technically reminded but will have a go Thanks
Hi Frogcake Going to check tomorrow. Don't really know how I stand with bike in track state would it make a difference to a recall ?? Can only ask.
