Camera and screen
Discussion in 'Accessories' started by StephenP, Mar 27, 2018.
  1. StephenP
    412
    Hey guys,
    After some advice, I've just got in the post today a small LCD screen with cameras for front and rear on the bike, I can record footage and also have eyes in the back of my head.
    My question is this, as it draws its power from the bike i need to wire it in, but I need advice on where best to wire it in without slicing through important wires.
    As in, can I just find the ignition wire and join it up with that? Surely there's a somewhat safer wire i can attach it to.
    Cheers!
  2. cpszx
    569
    which did you get? i was looking at some of these, mostly cheap chinese ones.
  3. StephenP
    412
    Was exactly that, got it off the wish app, nothing special but the screen works great and is bright and clear and the camera is pretty good too
    Pictures below, came with two cameras for front and rear, plus it records too
  4. StephenP
    412
  5. StephenP
    412
  6. cpszx
    569
    cheers, was similar to what i was looking at to stick on my commuter.
    i would attach to the battery directly, and not to any ignition switched wires.
    If you remove the screen when not in use, there will be no battery drain.
    if you get off the bike after an incident, you can keep recording any follow up without having to leave the keys in, etc
  7. Red675
    what about any *ahem* incriminating evidence, how easy is that to delete?
  8. StephenP
    412
    There's a simple format option in the menu, easier to not fit an SDcard and use it as a blind spot camera like I plan to do.
  9. cpszx
    569
    the one i was looking at had a simple on/off button on the handlebar, so if i happen to be doing something that might later be incriminating, i probably wouldn't want to record it anyway ;-)
    i would likely turn it on as i start having to filter, or in town, and then off again other times
  10. StephenP
    412
    Wired it into the side light today, works fine when I switch the ignition on, now just to route the wires around the bike to keep it tidy.
    And also find a small bracket to mount it under the screen so it doesn't hide the Speedo too much.
  11. cpszx
    569
    How are you getting on with this?
    Whats the quality like?
  12. StephenP
    412
    Not great to be honest, took it off now. Wasn't expecting much for what i paid
    Thinking a better quality one would be much better and it did suit a purpose.
  13. cpszx
    569
    haha.
    what was the issie?
    picture quality?
    usability?
    was it supposed to be hd, or just vga?
  14. StephenP
    412
    The screen was a bit small, also it would reset each time it turned off and back on which was a bit annoying.
    Also the camera view wasn't as wide angle as i wanted, it seemed too narrow.
