update on parts available now breaking . 06/07 frame with numbers £300 2012 fresh engine complete with kit generator 124bhp 53lbs of torque £1600 forks with 20mm k tech valve kit £380 yokes £50 ohlins race rear shock £450 arrow full clean stage 2 exhaust system £600 kit loom and ecu £350 tank with carbon protectors £150 pump £40 rearsets £120 gpr damper £150 clocks £60 front master £70 clip ons £60 radiator £50 fairings inc seat £100 Wheels with discs and carrier £360 Kit belmouths with BMC filter £100 Can email pictures & Happy to post parts at cost of tracked postage . Thanks James
Can you send me pictures of the rearsets, fairings inc seat and kit belmouths with bmc filter. thanks
I need a stand alone one for a older model under seat daytona Only problem is I need it tonight or tomorrow
update on parts available now breaking . 06/07 frame with numbers £300 2012 fresh engine complete with kit generator 124bhp 53lbs of torque £1600 forks with 20mm k tech valve kit £380 yokes £50 ohlins race rear shock £450 arrow full clean stage 2 exhaust system £600 tank with carbon protectors £150 pump £40 rearsets £120 gpr damper £150 clocks £60 front master £70 clip ons £60 fairings inc seat unit £100 Wheels and discs £360.00 Can email pictures & Happy to post parts at cost of tracked postage . Thanks James
Just removed the GPR damper and there is abit of light has weeped from the back of the damper Would recommend a service on it Complete damper £100 Thanks James
