765 electronics on a 675
Discussion in 'Racing' started by pp racing, Aug 12, 2025.
  1. pp racing
    pp racing
    Hi people
    Hoping someone can offer some advice
    I want to stick with the 675 engines as I have 2 in supersport trim but what I'm aiming to do is use the 765 electronics ,to be more specific I'm going down the mechtronics route as used in bsb and world supersport ,this will give me a modern race dash ,quickshifter plus auto blipper and all manner of data if I want
    So what I'm assuming is that so long as I use the 765 throttle bodies and airbox all the other sensors are pretty much in the same place as the engines visually are identical
    Any advice would be greatly appreciated
  2. panos_zip
    panos_zip
    51
    Hi,
    I saw your fb post. I m following this thread as I m also interested in this swap.
    In order to contribute to the thread,
    I have done the opposite, 765 motor with 675 electronics/sensors/airbox etc so I believe that the swap is doable.
    As you said the engines externally are almost identical. The electrical modifications were quite simple.
    Looking forward for updates on the project.
