675RS KDR triumph rebuild
Discussion in 'Accessories' started by T_daytona675, Jan 10, 2013.
  1. Why were they different?
  2. Good bit of info there nice to know about the earlier engines.
  3. T_daytona675
    Bearings are a different size to the normal triumph wheels
  4. T_daytona675
    The beast is nearly ready to run rad,headers,tank and carbon cover with new graphics all on.
  5. midgey46
    244
    White subframe is going to go well with your colour scheme :)
  6. Red675
    what bit are you saving to put on last?
  7. T_daytona675
    Fairings will be last thing on
  8. T_daytona675
    Started it up today all fluids in triple checked everything both went ahead and it started first time was very pleased.......it's been a joy to work on and impressed myself having stripped bike right down to just a frame and rebuilt, not many problems thankfully
  9. T_daytona675
    ImageUploadedBy675cc1431208120.446988.jpg ImageUploadedBy675cc1431208138.538083.jpg so that explains slipping clutch
    ImageUploadedBy675cc1431208212.659258.jpg new carbon tank covers with new graphics
    ImageUploadedBy675cc1431208256.182507.jpg ImageUploadedBy675cc1431208274.772043.jpg titanium wrapped headers
    Not much to do now should be on road this week all being well
  10. T_daytona675
    Not much left to do now.......thank god, all fitted up with new 320m disc, serviced forks, cleaned calipers and new wheels ImageUploadedBy675cc1431644658.109410.jpg ImageUploadedBy675cc1431644681.600480.jpg ImageUploadedBy675cc1431644705.279487.jpg
  11. T_daytona675
    Bike is now at long last, and I have to say it's been a pleasure to work on it was fully stripped to it just being a frame. I have replaced most nuts and bolts for pro bolt or similar, there was times I regretted taking on such a project so few upgrades are:
    Marchisni front wheel
    320m brembo discs
    Titanium exhaust wrap
    Carbon tank protection
    Kais serviced forks
    Replaced standard piping with red silicone
    O2 eliminator plug
    New graphics
    10-12 675r swing arm from Mr Jones
    White subframe
    Black side stand
    Race clock bracket
    New chain/sprockets
    Race front brake tube
    Evans coolant
    New clutch plates
    New heat shield
    And gold heat shield on bottom of air box
    Just few little bits left here and there but just really want to ride it now
  12. T_daytona675
  13. midgey46
    244
    Let me know how the coolant is, running temp wise :)
  14. T_daytona675
    It's great fella, worth getting
  15. midgey46
    244
    Think I'll do mine this winter, nine runs quite hot, want to do the expansion mod too
  16. Are your brembo spacers 10mm?
  17. T_daytona675
    Think they are 12?? Can't remember now had to get bigger ones to allow for the 320mm discs
  18. T_daytona675
    Not update for a good while, had a great year on the bike since rebuild was completed with ride outs etc and trip to IOM and then performance bikes photo shoot for feature due out in December.
    This road if modifications is very near its end after now upgrading some parts again gone from the ohlins TTX to a ohlins RSU unit and now PVM wheels with Brembo 320m discs, there is nothing really left to do apart from engine refresh with a little tuning but that will have to wait as think I've spent enough over past few weeks.
    Will post up pics once wheels are all fitted and bike cleaned.
  19. Will you give the heads up on the performance bikes spread as I would like to have a comprehensive read. Cheers
  20. T_daytona675
    The up to date spec list:
    Triumph 675RS Daytona 2007
    2009 front nose cone
    Power bronze screen
    Race clock mount
    Powder coated black yoke
    Bonimici handle bars
    Renthal grips
    Brake guard
    Rad guard/lower grill r&g
    19x20 brembo master cylinder
    ASV short levers
    Quick action throttle
    Race brake tube
    HM race dash
    Hel braided race lines
    Brembo M4 calipers
    SBS pads
    K-tech 25m fork internals (set up by kais)
    320m brembo discs
    PVM light weight wheel
    Captive spacers ( front and rear )
    Gold plated heat shield air box
    MWR air filter race
    Triumph velocity stacks (bell mouths)
    Remapped custom ECU ( 117 bhp)
    O2 sensor blank
    De-catted standard headers
    MHP exhaust
    Titanium exhaust heat wrap
    Samco hoses
    Silicone tube to air box and throttle bodies
    Bazzaz quick shifter
    HID lights and side lights
    Ohlins RSU rear shock ( kais set up)
    Race filler cap
    Integrated rear light
    Watsen front indicators (colour match)
    2012 675R swing arm (ex Luke Jones)
    GB racing engine guards
    GB racing fork spindle
    GB racing bobbins
    Carbon swing arm covers
    Carbon infills
    Carbon cockpit infills
    Carbon front mud guard
    Carbon rear mud guard
    Renthal sprockets-1 front +2 front
    DID x-ring gold chain 520
    Gilles rearsets
    Gilles chain adjusters
    Gilles axle nut
    Bi-tubo steering damper
    Wavy Rear disc
    R&G toe guard
    Hel rear brake line
    HRC rear race tube
    HRC over flow bottle
    Evans coolant
    Seat cowl
    Tech spec
    Lots of pro bolt replacement nuts
    Bike now lock wired
    Painted rear subframe (white)
    Custom race seat
    Custom vinyl graphics belly pan and seat unit and tank
    Moto graphics number board
    Custom vinyl number board on screen
    Removed:
    Sai unit
    Air flap
    Exup valve
    Cat converter
    Mirrors
    Rear pillion pegs
    Sent from my iPhone 6
