2019 765 RS engine 1k miles - convert your 675
Discussion in 'For Sale' started by Lenny675, Apr 8, 2020.
  1. Lenny675
    Lenny675
    414
    BB98FBEB-6C5E-44C1-9832-5E15BA8D1686.jpeg 8CD6BE6D-B5D0-4F86-9FE1-BA6FD85C1F88.jpeg E9C1B81D-F26C-4A61-A083-05BCA9B84650.jpeg F6F68C29-9BE4-4B5B-9356-1482ED6D753D.jpeg D7A5F089-10FE-4718-8261-41C25EE59653.jpeg 2019 765 RS engine.
    1k miles.
    Excellent condition.
    Removed from 2019 69 plate triumph street triple 765 RS which was broken for spares due to being subject to a cat B insurance loss.
    ideal engine upgrade for your 675.
    A fairly straight forward upgrade to an 2013+ 675/675R.
    £1600
  2. cpszx
    562
    What is "fairly straightforward" mate? What else needs to be changed?
    ECU? (ignition key/coding?) Headers?
    Also, where did you get the engine stand?
  3. Lenny675
    Lenny675
    414
    I have the engine stands made mate but don’t currently have any spare & the engineering shop that does them for me is closed.
    Easier conversion is to just swop the sump & oil pick up over from a 675 engine,
    Then you can use your existing headers & system.
    Use all your 675 running gear & electrics.
  4. & will need bazzaz or race ECU and full mapping as it’s very very different, will barely run without that (has to be able to map all 6 injectors, not just piggy back)
  5. SoCal675
    SoCal675
    Interesting will this work in an older generation do you? 2006-2012?
  6. GazP
    GazP
    545
    I’ve been wondering this! A 765 in a gen2
  7. Yes would fit but as said, all electronics will need to be fully mappable
  8. Lenny675
    Lenny675
    414
    I’ve been working on converting a gen2.
    It all looks feasible so far,
    I’ll be using a kit ecu & loom with tracks to allow us to tune.
  9. GazP
    GazP
    545
    Sorry gents, just want to make sure I’m not getting my gens mixed up. Gen 2 is 2010 - 2012 right? Last of the underseat exhausts?
  10. Gen 2 is 2009 (oval exhaust port, black engine) to 2012, the 2013 was a gen 3 model, with shorter stroke and wider bore and lots of other changes
  11. GazP
    GazP
    545
  12. Linool81
    Linool81
    155
    44
    Yes, I know its almost a year ago but stumbled across this thread and started thinking. Is it not possible to use throttle body from a 675 and pre 2013 ecu with a setup from tuneecu? Sure you wont get the ride by wire feature but still. Headers can be solved easy enough for such conversions.
  13. Daytona sump and oil pickup fit straight on.
    Think only problem using daytona ecu etc is the street is only designed for 12k revs, not 15k.
    Just got bores repaired on mine and head is being skimmed and ported by Dave Harris at The performance solution. (T3).
    Sent from my SM-G960F using 675.cc mobile app
  14. Linool81
    Linool81
    155
    44
    Here's my 2006 675 converted to 765. Used ecu and harness from 675 plus 675 air box, throttle bodies etc. 20210804_111457.jpeg
    Sent from my SM-G973F using 675.cc mobile app
  15. StMarks
    Looking very nice Nurse..
    Wondering if there was some reason for abandoning the underseat exhaust route (or just following current preferences).?
    Also how are you finding the results, or is it early days still.?
  16. Linool81
    Linool81
    155
    44
    Main reason for exhaust was that it had to be rebuilt because of the headers coming down on the other side with the 765 sc projects. But also because of the strict noise levels at tracks here in Sweden. Even put a 10cm silencer beside the sump. 20210717_130004.jpeg
  17. Linool81
    Linool81
    155
    44
    Brought back from dyno yesterday, gonna have a go on the upcoming weekend. 20210816_201607.jpeg
  18. Lewis
    Lewis
    7
    Assuming the 675 ecu wouldnt run it though? am just about to start this conversion into a 2014 STR
  19. Lewis
    Lewis
    7
    Im about to do this swap into a gen3, any pointers on electrics? be much appreciated.
  20. Linool81
    Linool81
    155
    44
    I used the ecu and harness from gen 2. ;)
