2008 675 Spec
Discussion in 'General' started by Craig, Nov 4, 2007.
  1. Craig
    Craig
    Administrator Staff Member
    4,893
    227
    Engine
    • Type: Liquid-cooled, 12 valve, DOHC, in-line 3-cylinder
    • Capacity: 675cc
    • Bore/Stroke: 74.0 x 52.3mm
    • Fuel System: Multipoint sequential electronic fuel injection with forced air induction
    Transmission
    • Final Drive: O ring chain
    • Clutch: Wet, multi-plate
    • Gearbox: 6-speed, close ratio
    Cycle Parts
    • Frame: Aluminium beam twin spar
    • Swingarm: Braced, twin-sided, aluminium alloy with adjustable pivot position
    • Front Wheel: Cast aluminium alloy 5-spoke, 17 x 3.5in
    • Rear Wheel: Cast aluminium alloy 5-spoke, 17 x 5.5in
    • Front Tyre: 120/70 ZR 17
    • Rear Tyre: 180/55 ZR 17
    • Front Suspension: Kayaba, 41mm upside down forks with adjustable preload, rebound and compression damping, 120mm travel
    • Rear Suspension: Kayab, Monoshock with biggy back reservoir, adjustable for preload, rebound and comporession damping 130mm rear wheel travel
    • Front Brakes: Twin 308mm floating discs, Nissin 4 piston radial calipers. Radial master cylinder
    • Rear Brakes: Single 220mm disc, Nissin single piston caliper
    Dimensions
    • Length: 2,010mm (79.1in)
    • Width (Handlebars): 700mm (27.5in)
    • Height: 1,120mm (44.0in)
    • Seat Height: 825mm (32.5in)
    • Wheelbase: 1,395mm (54.9in)
    • Rake/Trail: 23.9º/89.1mm
    • Dry Weight: 165kg (363lbs)
    • Fuel Tank Capacity: 17.4 litres (3.8 gal)
    Performance (Measured at crankshaft to DIN 70020)
    • Maximum Power: 125PS / 123bhp / 92kW @ 12,500 rpm
    • Maximum Torque: 72Nm / 53ft.lbf @ 11,750 rpm
    Colours: Neon Blue, Jet Black, Tornado Red, Special Edition - Phantom Black
    Price: Standard - £7,199.00 'on the road' retail, Special Edition - £7,349 'on the road' retail
