Another long shot, along with my request for some oval headers and set of hens teeth... Does anyone have a 11-12 675R front wheel available? Grey/black with thin red pinstripe under lacquer. Thanks
I have been working on a set of 13+ headers. The manifold is the same shape and fits perfect on 09 engine. I have kept the cat casing and slightly modified it where it hits the sump. Then I cut out the cat with drill and chisel. Took a while but came out fine. I cut up a set of old headers, any will do , to reuse the bent outlet piece and mounting. That leaves about a 4 inch long pipe to get welded in. Think I might need to wrap cat in heat tape aswell . Oval headers are getting very hard to find but these are quite cheap. Will let you know when I get it fired up with your Arrow can. Cheers Martin
