gb racing pulse cover marked £15 posted RLR race spec cams with adjustable wheels £120 POSTED kit 1st gear and housing kit £200 POSTED starter motor £50 POSTED oil cooler £50 POSTED clutch casing with carbon cover £30 POSTED pulse casing £20 POSTED crank shaft sensor £15 POSTED RLR ported and skimed flowed head 0.4mm with rlr kit valve springs, spacers and valves no 3 cylinder inlet the valve guide has broke ! The cylinder shop in England would make one and cut and fit the valve at a cost of £80 I can supply the new valve! all others valves are fine and still in the head £200 if any1 is interested 0.6mm kit head gasket needed to be fitted Job lot £350
RLR race spec cams with adjustable wheels £120 POSTED kit 1st gear and housing kit £200 POSTED starter motor £50 POSTED oil cooler £50 POSTED clutch casing with carbon cover £30 POSTED pulse casing £20 POSTED crank shaft sensor £15 POSTED RLR ported and skimed flowed head 0.4mm with rlr kit valve springs, spacers and valves no 3 cylinder inlet the valve guide has broke ! The cylinder shop in England would make one and cut and fit the valve at a cost of £80 I can supply the new valve! all others valves are fine and still in the head £200 if any1 is interested 0.6mm kit head gasket needed to be fitted All sold thanks
price list update bottom yokes £35 posted injectors £60 posted rear caliper with like new rear pads £35 posted rear caliper bracket £12 posted rear master cylinder £15 posted swingarm shock linkage and dog bone £25 posted airbox £18 posted rectifier £35 posted ignition pack £25 posted pulse cover £20 posted good crank £150 posted thanks james
Is that a swingarm including the linkage or is it just the linkage ? Sent from my Nexus 4 using Tapatalk
price list update sump £25 posted injectors £60 posted rear caliper with like new rear pads £35 posted rear caliper bracket £12 posted airbox £18 posted ignition pack £25 posted pulse cover £20 posted good crank £150 posted thanks james
