still for sale Full quill titanium system Engine parts Rear caliper Rear master cylinder Injectors Tank with carbon protecters rlr race cams Kit loom and ecu Rectifier Carbon hugger Kit bell mouths
Have no idea my rectifier doesn't say either of them codes Tank complete with carbon protecters and pump £150 Rlr race kit cams £120 Kit loom and ecu with kit bel mouths £250 Thanks James
Tank sold many thanks Engine parts inc crank etc Kit 1st gear and housing Rear caliper Rear master cylinder Bottom suspension linkage Injectors Bottom yokes rlr race cams All still for sale James
parts from my stripped supersport engine gb racing pulse cover marked £15 posted RLR race spec cams with adjustable wheels £120 POSTED kit 1st gear and housing kit £200 POSTED starter motor £50 POSTED oil cooler £50 POSTED clutch casing with carbon cover £30 POSTED pulse casing £20 POSTED crank shaft sensor £15 POSTED RLR ported and skimed flowed head 0.4mm with rlr kit valve springs, spacers and valves no 3 cylinder inlet the valve guide has broke ! The cylinder shop in England would make one and cut and fit the valve at a cost of £80 I can supply the new valve! all others valves are fine and still in the head £200 if any1 is interested 0.6mm kit head gasket needed to be fitted any1 interested in a job lot drop me a pm thanks james
Rear wheel spindle with wheel spacers and titanium rear nut £22 posted Front wheel spindle with spacers £15 posted
