Subframe Forks Bottom yokes Quill Titanium system Radiator Carbon hugger Front calipers Rear Caliper Wheels with discs Subframe blacking plates Still all for sale Thanks James
parts from my stripped supersport engine gb racing pulse cover £20 gb racing pulse cover marked £15 RLR race spec cams with adjustable wheels £200 kit 1st gear and housing kit £200 starter motor £50 oil cooler £50 clutch casing with carbon cover £40 pulse casing £20 crank shaft sensor £15 RLR ported and skimed flowed head 0.4mm with rlr kit valve springs, spacers and valves no 3 cylinder inlet the valve guide has broke ! The cylinder shop in England would make one and cut and fit the valve at a cost of £80 I can supply the new valve! all others valves are fine and still in the head £200 if any1 is interested 0.6mm kit head gasket needed to be fitted thanks james
Sent from my ST26i using Tapatalk 2 Do you have a wire loom just bought one off a member and it's. (fucked ) thanks
Whats the difference between the KIT race cams and the RLR cams? The same question for the RLR unlocked ECU?
the rlr cams are the same but just there own adjustable timing wheels the ecu is a genuine kit one rlr unlocked is they have opened up or chipped the ecu to get the best mapping set up with the cams and belmouths that they used all the belmouths are short ones which ive seen ones 2 high and one low I have also 3 high ones here that's about as much as I know bike was already all developed when was bought thanks james
